Ir para o conteúdo principal
Lovaky PC230A Battery Replacement
O que você precisa
  1. Lovaky PC230A Battery Replacement, Battery: passo 1, imagem 1 %32 Lovaky PC230A Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn off the keyboard by sliding the power switch to the off position. The switch is located on the top right of the front of the keyboard.
    • Make sure that the keyboard is powered off before beginning to do any work on it. Working on the device with the power on can possibly lead to electric shock.
  2. Lovaky PC230A Battery Replacement: passo 2, imagem 1 %32 Lovaky PC230A Battery Replacement: passo 2, imagem 2 %32
    • Turn over the keyboard and remove the cover to the battery compartment by lifting the tab of the battery cover up and off.
    • You can use your fingernail to do this or a wedging tool to help remove the battery cover.
    • Take the faulty battery out of the battery compartment by pushing the battery towards the spring and lifting the other end of the battery out of the compartment.
    • When inserting the new battery make sure the flat side goes against the spring and the studded side goes against the flat side.
Conclusão
Sadie Bickford
Membro desde: 03/18/24
135 Reputação
Autoria de 1 guia
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 114
