Ir para o conteúdo principal
Lorex MC6950 Camera Lens Replacement
O que você precisa
  1. Lorex MC6950 Camera Lens Replacement, Camera Lens: passo 1, imagem 1 %32 Lorex MC6950 Camera Lens Replacement, Camera Lens: passo 1, imagem 2 %32
    • To remove a bad lens, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
  2. Lorex MC6950 Camera Lens Replacement: passo 2, imagem 1 %32 Lorex MC6950 Camera Lens Replacement: passo 2, imagem 2 %32
    • Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
    • Once the camera is removed, remove the wires from the outer containment shell.
    • Be careful. The metal spudger could damage the camera if not handled with care.
  3. Lorex MC6950 Camera Lens Replacement: passo 3, imagem 1 %32 Lorex MC6950 Camera Lens Replacement: passo 3, imagem 2 %32
    • With the camera in hand, the circuit board must be separated from the LED containment shell. There is a 5mm JIS 0 screw at every corner of the circuit board.
    • The wires attaching the circuit board to the shell should be removed as well.
  4. Lorex MC6950 Camera Lens Replacement: passo 4, imagem 1 %32
    • Now the motor housing must be removed from the circuit board first as it is in the way of the screws associated with the lens. There are three 5mm JIS 0 screws located on the lens side of the circuit board to remove the motor.
  5. Lorex MC6950 Camera Lens Replacement: passo 5, imagem 1 %32
    • The lens has two 5 mm JIS 0 screws located under the motor's previous location. Once these are removed, the lens can be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Elijah Conlin
Membro desde: 11/07/17
379 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G2, Harley Fall 2017 Membro de IUPUI, Team S2-G2, Harley Fall 2017
IUPUI-HARLEY-F17S2G2
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 816
