Pular para o conteúdo principal
Introdução
This guide explains how to re-attach the WiFi antenna.
  1. Remove the 5.0mm screw using the Phillips #0 head screwdriver.
    • Remove the 5.0mm screw using the Phillips #0 head screwdriver.
  2. Insert metal spudger as shown in the picture. Move spudger along  to the other side until both snaps come loose.
    • Insert metal spudger as shown in the picture. Move spudger along to the other side until both snaps come loose.
  3. Picture shows the removed battery cover.
    • Picture shows the removed battery cover.
  4. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Slide the battery out by pulling on one of two plastics tabs.
    • Slide the battery out by pulling on one of two plastics tabs.
  6. Remove the remaining five 6.0 mm Phillips #0 screws.
    • Remove the remaining five 6.0 mm Phillips #0 screws.
  7. Use the spudger to remove the back cover. Insert the spudger between the back and front cover. Once inserted, you will need to move it around the perimeter to release the snaps holding it together.
    • Use the spudger to remove the back cover. Insert the spudger between the back and front cover. Once inserted, you will need to move it around the perimeter to release the snaps holding it together.
  8. Once back cover is removed, the speaker wire will need to be removed. Use tweezers to remove wire.
    • Once back cover is removed, the speaker wire will need to be removed. Use tweezers to remove wire.
  9. Begin by heating the exposed end of the grey lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
    • Begin by heating the exposed end of the grey lead with the tip of a soldering iron while simultaneously pulling the lead away from the connection, using tweezers to grasp the lead by the insulation.
    • For more information on soldering, check out this repair guide: iFixit Soldering
Conclusão
Yancey Crase
Membro desde: 26-03-2018
217 reputação
2 Guias de autoria
Equipe
IUPUI, Team S1-G4, Harley Spring 2018 Membro de IUPUI, Team S1-G4, Harley Spring 2018
IUPUI-HARLEY-S18S1G4
7 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 81
