Ir para o conteúdo principal
Lorex LW2742 Microphone Replacement
O que você precisa
  1. Lorex LW2742 Microphone Replacement, Microphone: passo 1, imagem 1 %32 Lorex LW2742 Microphone Replacement, Microphone: passo 1, imagem 2 %32
    • Remove the six 10mm Torx T10 screws on camera face.
  2. Lorex LW2742 Microphone Replacement: passo 2, imagem 1 %32
    • Remove the exterior lens cover.
  3. Lorex LW2742 Microphone Replacement: passo 3, imagem 1 %32 Lorex LW2742 Microphone Replacement: passo 3, imagem 2 %32 Lorex LW2742 Microphone Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Microphone Replacement: passo 4, imagem 1 %32
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the left and right 8mm screws first. Followed by the top and bottom 5mm screws.
  5. Lorex LW2742 Microphone Replacement: passo 5, imagem 1 %32
  6. Lorex LW2742 Microphone Replacement: passo 6, imagem 1 %32 Lorex LW2742 Microphone Replacement: passo 6, imagem 2 %32 Lorex LW2742 Microphone Replacement: passo 6, imagem 3 %32
    • Use tweezers to disconnect the microphone wires from the internal components of camera.
  7. Lorex LW2742 Microphone Replacement: passo 7, imagem 1 %32 Lorex LW2742 Microphone Replacement: passo 7, imagem 2 %32 Lorex LW2742 Microphone Replacement: passo 7, imagem 3 %32
    • Remove the 4mm Flathead #4 screw on the bottom of the camera.
    • Remove the weatherproof gasket around the microphone with tweezers.
  8. Lorex LW2742 Microphone Replacement: passo 8, imagem 1 %32 Lorex LW2742 Microphone Replacement: passo 8, imagem 2 %32 Lorex LW2742 Microphone Replacement: passo 8, imagem 3 %32
    • Remove the microphone.
    • Push the microphone from the inside out for easier removal.
Conclusão
Alex Kusmierz
Membro desde: 09/26/16
601 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-1, Eyestone Fall 2016 Membro de USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 276
