Ir para o conteúdo principal
Lorex LW2742 Lens Replacement
O que você precisa
  1. Lorex LW2742 Lens Replacement, Lens: passo 1, imagem 1 %32 Lorex LW2742 Lens Replacement, Lens: passo 1, imagem 2 %32
    • Remove the six 10mm Torx T10 screws on the camera face.
  2. Lorex LW2742 Lens Replacement: passo 2, imagem 1 %32
    • Remove the exterior lens cover.
  3. Lorex LW2742 Lens Replacement: passo 3, imagem 1 %32 Lorex LW2742 Lens Replacement: passo 3, imagem 2 %32 Lorex LW2742 Lens Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the foam ring around the lens with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
  4. Lorex LW2742 Lens Replacement: passo 4, imagem 1 %32
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
  5. Lorex LW2742 Lens Replacement: passo 5, imagem 1 %32
    • Remove the LED board with tweezers.
    • It is unnecessary to unplug the LED board from internal components for lens replacement.
  6. Lorex LW2742 Lens Replacement: passo 6, imagem 1 %32 Lorex LW2742 Lens Replacement: passo 6, imagem 2 %32
    • Use the Phillips #000 to remove the three 3mm screws on the face of the camera lens
  7. Lorex LW2742 Lens Replacement: passo 7, imagem 1 %32
    • Remove the camera lens.
    • After replacing camera lens and before reassembly it is encouraged to clean new lens surface with a microfiber lens cleaning cloth
Conclusão
Alex Kusmierz
Membro desde: 09/26/16
601 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 16-1, Eyestone Fall 2016 Membro de USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 937
