Introdução
Any avid rider of longboards can attest the feeling of smooth cruising is paramount in the skating experience. Drag induced by grime building up in wheel bearings is literally that: a drag. The process outlined here serves as an introduction to longboard maintenance, focusing on the components of the wheel as well as how to maximize their efficiency.
An easy way to test the state of one’s wheels is to spin each independently and time how long it takes to come to rest. Generally, if a wheel spins less than thirty seconds it will detriment the quality of the motion. However, even if this criteria isn’t met, visible build up of grime signals the need for maintenance.
O que você precisa
Remove the wheel components from the axle starting with the cap nut.
While the fix itself is relatively simple, it requires time to allow the bearings to be cleaned properly. Be mindful of where the smaller components are placed as one can lose track of them easily. Also, be sure to employ caution when using the box cutter.
