Ir para o conteúdo principal
Logitech driving force gt ''play''or ''loose'' steering fix
O que você precisa
  1. Logitech driving force gt ''play''or ''loose'' steering fix, Driving Force GT: passo 1, imagem 1 %32
    • Remove Phillips Head Screws and open the cover. Before you touch anything be sure to touch a grounded object.It will be just fine to remove the static electricity, you may have.
  2. Logitech driving force gt ''play''or ''loose'' steering fix: passo 2, imagem 1 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 2, imagem 2 %32
    • Unplug the cables from the board and be sure to remember where they fit before disassemble them!
  3. Logitech driving force gt ''play''or ''loose'' steering fix: passo 3, imagem 1 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 3, imagem 2 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 3, imagem 3 %32
    • Remove the Phillips Head Screws that hold the base of the steering wheel.Before you remove the wheel please be cautious to remember where the gears attach each other. So it would be very nice if you mark the spot where they are in touch. When you assemble the wheel attach the gears in the same place as they were from factory.
  4. Logitech driving force gt ''play''or ''loose'' steering fix: passo 4, imagem 1 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 4, imagem 2 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 4, imagem 3 %32
    • So here is the crack and we are ready to take the wheel apart. The crack is the reason for your loose or play feeling of your wheel. The red circles indicate the spots, where you should open holes with your solder iron! Through these holes the zip ties are going to pass around and make the plastic strong again!
  5. Logitech driving force gt ''play''or ''loose'' steering fix: passo 5, imagem 1 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 5, imagem 2 %32 Logitech driving force gt ''play''or ''loose'' steering fix: passo 5, imagem 3 %32
    • So we will try to open some holes around the broken plastic, with the solder iron.The holes should be as big as for the zip ties can pass through them.Our aim is to tie the zip ties around the plastic.
  6. Logitech driving force gt ''play''or ''loose'' steering fix: passo 6, imagem 1 %32
    • So its time to pass the zip ties around the broken plastic and remove the loose or play feeling.
  7. Logitech driving force gt ''play''or ''loose'' steering fix: passo 7, imagem 1 %32
    • So here is the wheel with zip ties around it. The crack is fixed and zip ties hold it tied and strong again!Time to play some racing games!
Conclusão
9 outras pessoas executaram este guia.
Angelo P
Membro desde: 05/13/17
381 Reputação
Autoria de 1 guia
6 comentários
Thank you! Worked perfect! 10/10 would zip tie steering wheel again
LNswat - Responder
Well i did it and so far it's GREAT! Only thing i did different was drilled the holes because i don't own a soldering tool. Thank you for taking the time to post this fix!
M King - Responder
AMAZING GUIDE!! it really did the trick!!
Matteo Coppola Neri - Responder
I have a problem when I want turn left or right the vibration is high this tutorial will be fix the problem??
BigZee - Responder
Just fixed my idle noisy wiggle using your way! thanks! Definetly recommend to others !
TheQ 1337 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 104
Ao todo: 24,573
