Ir para o conteúdo principal
Logitech Z4 Desk Speaker Disassembly
O que você precisa
  1. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: passo 1, imagem 1 %32 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: passo 1, imagem 2 %32 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: passo 1, imagem 3 %32
    • Use a PH2 screwdriver to remove the two screws on the back of the speaker.
    • the speaker has a cinch connector to plug in to the sub-woofer.
  2. Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: passo 2, imagem 1 %32 Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: passo 2, imagem 2 %32
    • removing the decorative front panel with a plastic pick (guitar picks work great). it is quite sturdy but the adhesive film on the back of it is strong, so go slow or heat it up with a hairdryer.
  3. Logitech Z4 Desk Speaker Disassembly, Removing the housing screws: passo 3, imagem 1 %32
    • removing the main screws for the speaker housing. using the same driver (PH2) we can remove the 8 screws holding the main speaker assembly together.
  4. Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: passo 4, imagem 1 %32 Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: passo 4, imagem 2 %32
    • opening the speaker housing by prying it up evenly on all sides with the plastic pick.
    • it can be tapped lightly on the desk to make it fall out at the end of the process.
  5. Logitech Z4 Desk Speaker Disassembly, Taking inventory: passo 5, imagem 1 %32 Logitech Z4 Desk Speaker Disassembly, Taking inventory: passo 5, imagem 2 %32 Logitech Z4 Desk Speaker Disassembly, Taking inventory: passo 5, imagem 3 %32
    • after opening the speaker fully you can see that the top and bottom membranes are not speakers, only decoration.
    • the middle one is connected with two wires matching the cinch connector on the cable.
    • the cable has a screw and some hot glue acting as a strain release for the cable.
Conclusão
5 outras pessoas executaram este guia.
kugelzucker
Membro desde: 03/08/16
315 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 52
Duração total: 2,209
