Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
A soldering kit is necessary to completely isolate the motherboard as we will be needing to desolder the USB and camera joints.
O que você precisa
Grasp the white connector attaching the button chip wire to the motherboard.
Wiggle the connector back and forth to remove it from the connection box
Grasp the white wire connector between the tabs and the socket.
Wiggle the connector back and forth to remove the front cover from the motherboard.
Use tweezers to grasp the white wire connector on the back of the motherboard.
Wiggle the connector back and forth to remove it from the socket.
Uma outra pessoa concluiu este guia.
