Ir para o conteúdo principal
Logitech Webcam Pro 9000 Front and Back Cover Replacement
O que você precisa
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: passo 1, imagem 1 %32 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: passo 1, imagem 2 %32
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: passo 2, imagem 1 %32 Logitech Webcam Pro 9000 Front and Back Cover Replacement: passo 2, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Conclusão
Equipe
Cal Poly, Team 12-34, Amido Spring 2013 Membro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 1,243
