Introdução
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom outer mesh.
O que você precisa
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Uma outra pessoa concluiu este guia.
2 comentários
You know where to buy a replacement mesh in custom colors
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
