Ir para o conteúdo principal
Logitech UE MegaBoom Outer Mesh Replacement
O que você precisa
  1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: passo 1, imagem 1 %32 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: passo 1, imagem 2 %32 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: passo 1, imagem 3 %32
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Outer Mesh Replacement: passo 2, imagem 1 %32 Logitech UE MegaBoom Outer Mesh Replacement: passo 2, imagem 2 %32 Logitech UE MegaBoom Outer Mesh Replacement: passo 2, imagem 3 %32
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Outer Mesh Replacement: passo 3, imagem 1 %32 Logitech UE MegaBoom Outer Mesh Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
Conclusão
Uma outra pessoa concluiu este guia.
Oscar Ambriz
Membro desde: 09/27/17
958 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S9-G2, Banghart Fall 2017 Membro de Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
Membros da 4
Autoria de 14 guias
2 comentários
You know where to buy a replacement mesh in custom colors
Jonathan Lang - Responder
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 3,874
