Ir para o conteúdo principal
Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
O que você precisa
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: passo 1, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: passo 1, imagem 2 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: passo 1, imagem 3 %32
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 2, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 2, imagem 2 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 2, imagem 3 %32
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 3, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: passo 4, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: passo 4, imagem 2 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: passo 4, imagem 3 %32
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 5, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 5, imagem 2 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 5, imagem 3 %32
    Comprar
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 6, imagem 1 %32 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: passo 6, imagem 2 %32
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
Conclusão
3 outras pessoas executaram este guia.
Oscar Ambriz
Membro desde: 09/27/17
958 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S9-G2, Banghart Fall 2017 Membro de Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
Membros da 4
Autoria de 14 guias
10 comentários
How can I purchase this part being replaced thanks
Joseph Anderson - Responder
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - Responder
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - Responder
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 98
Duração total: 11,522
