Ir para o conteúdo principal
Logitech UE MegaBoom 3 USB Port Replacement
O que você precisa
  1. Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: passo 1, imagem 1 %32 Logitech UE MegaBoom 3 USB Port Replacement, General Disassembly: passo 1, imagem 2 %32
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 USB Port Replacement: passo 2, imagem 1 %32 Logitech UE MegaBoom 3 USB Port Replacement: passo 2, imagem 2 %32 Logitech UE MegaBoom 3 USB Port Replacement: passo 2, imagem 3 %32
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 USB Port Replacement, USB Port: passo 3, imagem 1 %32 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: passo 3, imagem 2 %32 Logitech UE MegaBoom 3 USB Port Replacement, USB Port: passo 3, imagem 3 %32
    • To remove the plastic frame that’s covering the charging board, use a Phillips #0 to remove both 2.4 mm screws.
    • Replace the charging port.
Conclusão
Anthony Miles
Membro desde: 09/04/23
981 Reputação
Autoria de 6 guias
Equipe
3 comentários
Thanks for the guide, this was very helpful!
Jason Doland - Responder
How easy/hard would it be to upgrade the charging port to usb-c?
Nenad Tarlac - Responder
This would be nearly impossible because micro-usb and usb type-c use different pinout (different number of pins...) and require different layout of the connection points on the charging PCB. And also the size of the usb-c socket is different.⏎
To do such modification it would require altering the charging PCB board, speaker housing (hole for the charging socket) and jumping (soldering very thin enamelled wires) from the usb-c connector to the different points on the charging PCB board.
Also this wouldn't increase the maximum charging speed, it would just be for the convenience of using one type-c cable with different modern devices.
Simon -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 207
