Ir para o conteúdo principal
Logitech UE MegaBoom 3 Passive Radiator Replacement
O que você precisa
  1. Logitech UE MegaBoom 3 Passive Radiator Replacement, General Disassembly: passo 1, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement, General Disassembly: passo 1, imagem 2 %32
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 2, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 2, imagem 2 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 2, imagem 3 %32
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: passo 3, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: passo 3, imagem 2 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: passo 3, imagem 3 %32
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 4, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 4, imagem 2 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 4, imagem 3 %32
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 5, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 5, imagem 2 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 5, imagem 3 %32
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
  6. Logitech UE MegaBoom 3 Passive Radiator Replacement, Passive Radiator: passo 6, imagem 1 %32 Logitech UE MegaBoom 3 Passive Radiator Replacement, Passive Radiator: passo 6, imagem 2 %32
    • Take off the metal rods by gently prying them out using the metal spudgers
    • Be sure to slide them out as gently as possible to prevent the rods from becoming damaged.
  7. Logitech UE MegaBoom 3 Passive Radiator Replacement: passo 7, imagem 1 %32
    • One the rods are removed you can pry it off and disconnect the passive radiator.
    • Repeat the same steps to disconnect the passive radiator on the other side of the speaker.
Conclusão
Anthony Miles
Membro desde: 09/04/23
981 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 121
