Ir para o conteúdo principal
Logitech UE MegaBoom 3 Battery Replacement
O que você precisa
  1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: passo 1, imagem 1 %32 Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: passo 1, imagem 2 %32
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE MegaBoom 3 Battery Replacement: passo 2, imagem 1 %32 Logitech UE MegaBoom 3 Battery Replacement: passo 2, imagem 2 %32 Logitech UE MegaBoom 3 Battery Replacement: passo 2, imagem 3 %32
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, imagem 1 %32 Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, imagem 2 %32 Logitech UE MegaBoom 3 Battery Replacement, Battery: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
    • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
    • The battery should slide out as you pull against it with the plyers.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
Conclusão
4 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 48
Últimos 30 dias: 234
Ao todo: 3,779
