Ir para o conteúdo principal
Logitech UE Hyperboom DC Power Socket Replacement
O que você precisa
  1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: passo 1, imagem 1 %32 Logitech UE Hyperboom DC Power Socket Replacement, Handle: passo 1, imagem 2 %32
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: passo 2, imagem 1 %32 Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: passo 2, imagem 2 %32
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Hyperboom DC Power Socket Replacement: passo 3, imagem 1 %32 Logitech UE Hyperboom DC Power Socket Replacement: passo 3, imagem 2 %32 Logitech UE Hyperboom DC Power Socket Replacement: passo 3, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    Pergunte ao FixBot
    Comentar
  4. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, imagem 1 %32 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, imagem 2 %32 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, imagem 3 %32
    • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
    • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
    Pergunte ao FixBot
    Comentar
  5. Logitech UE Hyperboom DC Power Socket Replacement: passo 5, imagem 1 %32 Logitech UE Hyperboom DC Power Socket Replacement: passo 5, imagem 2 %32
    • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
    • Pull the circuit board away from the panel.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 40
Ao todo: 75
