Ir para o conteúdo principal
Logitech UE Boom 3 Battery Replacement
O que você precisa
  1. Logitech UE Boom 3 Battery Replacement, Base: passo 1, imagem 1 %32 Logitech UE Boom 3 Battery Replacement, Base: passo 1, imagem 2 %32
    • Flip the speaker so the base is facing upwards.
    • Place the iFixit opening picks in the gaps of the speaker.
    • Use the picks to pry open the speaker.
    Pergunte ao FixBot
    Comentar
  2. Logitech UE Boom 3 Battery Replacement: passo 2, imagem 1 %32 Logitech UE Boom 3 Battery Replacement: passo 2, imagem 2 %32
    • Use a Jimmy to completely pry the base away from the rest of the speaker.
    Pergunte ao FixBot
    Comentar
  3. Logitech UE Boom 3 Battery Replacement, Battery: passo 3, imagem 1 %32 Logitech UE Boom 3 Battery Replacement, Battery: passo 3, imagem 2 %32 Logitech UE Boom 3 Battery Replacement, Battery: passo 3, imagem 3 %32
    • Remove the adhesive strap holding the battery in place.
    • It is sticky and tightly bounded, but removal is necessary.
    • Pull out the battery by hand until it is out of the casing and being held by the cable only.
    Pergunte ao FixBot
    Comentar
  4. Logitech UE Boom 3 Battery Replacement: passo 4, imagem 1 %32 Logitech UE Boom 3 Battery Replacement: passo 4, imagem 2 %32
    • The battery will still be attached to motherboard via cable.
    • Carefully press down on the lever on the end of the cable and disconnect it from the motherboard.
    • This cable is intricate and is susceptible to damage beyond repair. Be extra careful to precisely insert and remove the cable as bending the pins can result in damage.
    • Remove the battery from the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ethan Donahue
Membro desde: 03/18/24
600 Reputação
Autoria de 6 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 63
Últimos 30 dias: 233
Ao todo: 5,012
