Ir para o conteúdo principal
Logitech Slim Folio Battery Replacement
O que você precisa
  1. Logitech Slim Folio Battery Replacement, Open the case: passo 1, imagem 1 %32 Logitech Slim Folio Battery Replacement, Open the case: passo 1, imagem 2 %32 Logitech Slim Folio Battery Replacement, Open the case: passo 1, imagem 3 %32
    • Open your case and lay it out flat.
  2. Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: passo 2, imagem 1 %32 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: passo 2, imagem 2 %32 Logitech Slim Folio Battery Replacement, Pull the iPad away from the case: passo 2, imagem 3 %32
    • Grip the two case corners closest to the keyboard with your thumbs and pull them down, away from the iPad.
    • Remove the iPad from the case.
  3. Logitech Slim Folio Battery Replacement, Locate the battery tray: passo 3, imagem 1 %32 Logitech Slim Folio Battery Replacement, Locate the battery tray: passo 3, imagem 2 %32
    • Fold the case in half, so the keyboard is facing up.
    • Locate the battery tray.
  4. Logitech Slim Folio Battery Replacement, Open the battery tray: passo 4, imagem 1 %32 Logitech Slim Folio Battery Replacement, Open the battery tray: passo 4, imagem 2 %32 Logitech Slim Folio Battery Replacement, Open the battery tray: passo 4, imagem 3 %32
    • Insert the pointed end of a spudger into the access hole on the battery tray.
    • Push the spudger in, down, and pull the spudger towards you.
    • The battery tray should "click" open.
  5. Logitech Slim Folio Battery Replacement, Remove the battery tray: passo 5, imagem 1 %32 Logitech Slim Folio Battery Replacement, Remove the battery tray: passo 5, imagem 2 %32
    • Insert the flat edge of the spudger into the top of the battery tray.
    • Push the battery tray out, away from the case, until you can grip it with your fingers.
  6. Logitech Slim Folio Battery Replacement: passo 6, imagem 1 %32 Logitech Slim Folio Battery Replacement: passo 6, imagem 2 %32
    • Remove the battery tray.
  7. Logitech Slim Folio Battery Replacement, Remove the batteries: passo 7, imagem 1 %32 Logitech Slim Folio Battery Replacement, Remove the batteries: passo 7, imagem 2 %32 Logitech Slim Folio Battery Replacement, Remove the batteries: passo 7, imagem 3 %32
    • Flip the battery tray over.
    • Use the pointed end of the spudger to push both batteries out of the tray.
    • Remove the batteries.
  8. Logitech Slim Folio Battery Replacement, Reinstallation tip: passo 8, imagem 1 %32 Logitech Slim Folio Battery Replacement, Reinstallation tip: passo 8, imagem 2 %32 Logitech Slim Folio Battery Replacement, Reinstallation tip: passo 8, imagem 3 %32
    • To install new batteries:
    • Press one edge of a CR2032 coin cell battery against the contact arm, its text and "+" sign facing up.
    • Press to fully seat the battery.
    • Repeat for the second battery.
Conclusão
33 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
113.952 Reputação
Autoria de 338 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.175 guias
12 comentários
Excellent instructions. So easy - you made me a hero!
edspecial - Responder
So easy to do. I’m up and running again!
Susan Hallett - Responder
when you put the battery tray back in, you have to push it kind of hard to get it to go all the way in. I didn’t have a spudger but was able to use an ice pick (gently) and then a small flat screw driver.
pdmd - Responder
What if you don’t have a spider? Is there anything else that you can use to open the battery tray?
Kathy Pecsko - Responder
You can use something pointy instead of a Spudger. For example: A pair of scissors ✂️. You can open them with the pointy blade. Thanks!
Cheryl Xu -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 204
Últimos 7 dias: 1,468
Últimos 30 dias: 7,321
Duração total: 202,591
