Ir para o conteúdo principal
Logitech Signature M650 L Scroll Wheel Assembly Replacement
O que você precisa
  1. Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 1, imagem 1 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 1, imagem 2 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement, Scroll Wheel Assembly: passo 1, imagem 3 %32
    • Slide the battery compartment cover downward and lift it away from the mouse.
    Pergunte ao FixBot
  2. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 2, imagem 1 %32
    • Remove the AA battery from the battery compartment.
    Pergunte ao FixBot
  3. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 3, imagem 1 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 3, imagem 2 %32
    • Remove the USB receiver from its storage slot inside the battery compartment.
    Pergunte ao FixBot
  4. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 4, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws securing the internal frame.
    Pergunte ao FixBot
  5. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 5, imagem 1 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 5, imagem 2 %32
    • Gently lift the top shell away from the mouse body.
    • Do not remove it completely, as it is still connected to the base by a cable.
    Pergunte ao FixBot
  6. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 6, imagem 1 %32
    • Use a Phillips #000 screwdriver to remove the two screws securing the scroll wheel assembly.
    Pergunte ao FixBot
  7. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 7, imagem 1 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 7, imagem 2 %32
    • Lift the scroll wheel assembly out of the mouse and install the replacement assembly in the same position.
    Pergunte ao FixBot
  8. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 8, imagem 1 %32
    • Replace the two Phillips #000 screws to secure the scroll wheel assembly.
    Pergunte ao FixBot
  9. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 9, imagem 1 %32
    • Align the top shell with the base and press down along the edges until it snaps into place.
    Pergunte ao FixBot
  10. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 10, imagem 1 %32
    • Use a Phillips #000 screwdriver to reinstall the two internal screws.
    Pergunte ao FixBot
  11. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 11, imagem 1 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 11, imagem 2 %32 Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 11, imagem 3 %32
    • Insert the AA battery, reinstall the USB receiver, and slide the battery compartment cover back into place.
    Pergunte ao FixBot
  12. Logitech Signature M650 L Scroll Wheel Assembly Replacement: passo 12, imagem 1 %32
    • Your mouse is now fully reassembled.
    Pergunte ao FixBot
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 42
Ao todo: 78
