O que você precisa
To remove the plastic cover. You want to use the plastic opener and starting with corners.
Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
Quase terminado!
Conclusão
