Introdução
1- Remove the cover where you replace the battery.
2 - Below each battery, there is a screw that you remove with a small Philips screwdriver.
3 - At the top of the back part of the mouse there are two rubber finishes that you remove (it has an adhesive) and there you will find the screws that hold the top.
4 - It gets loose immediately, please be careful with the wire that connects one part to another, please disconnect this wire.
O que você precisa
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
