Introdução
The scroll wheel on this gaming mouse has holes in it that the optical sensor uses to detect when the wheel is turning. If dirt or other foreign material covers the sensor or the holes, the scroll wheel will stop working or may only work intermittently. This guide will demonstrate how to open the mouse and take the wheel assembly apart for cleaning.
O que você precisa
Use a thin blade to peel up the corners and remove the mouse feet. They re-adhere very well, so be careful to not damage them or get the sticky side dirty.
Unscrew the three screws that are now visible.
Gently pull apart the top and bottom halves of the mouse. They will be connected by a wire.
Plug the mouse back in to a computer and test for responsiveness. If the mouse wheel is clean but still does not function, contact Logitech support.
49 outras pessoas executaram este guia.
31 comentários
It worked! Thank you so much!
got my scroll wheel back from just being intermittent. nice guide for the best mouse ever made. All hail the mighty MX518, shotter of many heads, destroyer of Skyrim, Diablo I,II,III and lately bearer of the Witchers mighty blades. HAIL HAIL HAIL MX518!!!
My mouse went from scrolling just fine to nothing overnight. This helped a lot, but sadly its still not 100%. :(
Worked like a charm. Thanks. I really like this mouse and didn't want to have to get used to another one.
Fantastic!!! I've been really reluctant to replace my MX510 mouse -- your teardown of this one (which the internals appear to be identical anyway) was perfect!
My mouse is running like brand new again!
