Ir para o conteúdo principal
Logitech MX Keys Key Replacement
O que você precisa
  1. Logitech MX Keys Key Replacement, Take out key: passo 1, imagem 1 %32
    • Insert something thin under the top of the key.
    • Apply a little force. It comes out easily.
  2. Logitech MX Keys Key Replacement, Anatomy of a key: passo 2, imagem 1 %32 Logitech MX Keys Key Replacement, Anatomy of a key: passo 2, imagem 2 %32
    • Anatomy of a key
  3. Logitech MX Keys Key Replacement, Put key back: passo 3, imagem 1 %32 Logitech MX Keys Key Replacement, Put key back: passo 3, imagem 2 %32
    • Slide in bottom first
    • Gently push the top part in. It clips easily.
Conclusão
3 outras pessoas executaram este guia.
sitarane
Membro desde: 09/10/15
512 Reputação
Autoria de 1 guia
12 comentários
Do you think the clips are durable?
Joshua M - Responder
No, they break easily.
ikomrad -
Where can I find the keys for the replacement? I can only find keys for like $15 per key...
Fritz Freund - Responder
I need to know this too!
ikomrad -
If you are having sticky key issues, take the key out, clean out the area beneath the key, and underneath the key, and reinsert the same key. In most cases, this will fix your issue. This may happen if debree/dust gets in-between the keys.
Gitesh Agarwal -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 46
Últimos 7 dias: 257
Últimos 30 dias: 1,194
Duração total: 30,830
