Ir para o conteúdo principal
Logitech MX Keys Key Removal and Replacement
O que você precisa
  1. Logitech MX Keys Key Removal and Replacement, Take out key: passo 1, imagem 1 %32
    • Insert something thin under the top of the key.
    • Apply a little force. It comes out easily.
  2. Logitech MX Keys Key Removal and Replacement, Anatomy of a key: passo 2, imagem 1 %32 Logitech MX Keys Key Removal and Replacement, Anatomy of a key: passo 2, imagem 2 %32
    • Anatomy of a key
  3. Logitech MX Keys Key Removal and Replacement, Put key back: passo 3, imagem 1 %32 Logitech MX Keys Key Removal and Replacement, Put key back: passo 3, imagem 2 %32
    • Slide in bottom first
    • Gently push the top part in. It clips easily.
Conclusão
You've successfully removed and replaced a keycap on your Logitech MX Keys keyboard.
25 outras pessoas executaram este guia.
sitarane
Membro desde: 09/10/15
996 Reputação
Autoria de 1 guia
24Comentários do guia
Do you think the clips are durable?
Joshua M - Responder
No, they break easily.
ikomrad -
Where can I find the keys for the replacement? I can only find keys for like $15 per key...
Fritz Freund - Responder
I need to know this too!
ikomrad -
If you are having sticky key issues, take the key out, clean out the area beneath the key, and underneath the key, and reinsert the same key. In most cases, this will fix your issue. This may happen if debree/dust gets in-between the keys.
Gitesh Agarwal -
Comentar
Visualizações:
Últimas 24 horas: 91
Últimos 7 dias: 569
Últimos 30 dias: 2,649
Ao todo: 68,241
