Ir para o conteúdo principal
Logitech MBJ58 Mouse Support Spring Replacement
O que você precisa
  1. Logitech MBJ58 Mouse Support Spring Replacement, Top cover: passo 1, imagem 1 %32
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    Pergunte ao FixBot
    Comentar
  2. Logitech MBJ58 Mouse Support Spring Replacement: passo 2, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement: passo 2, imagem 2 %32
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    Pergunte ao FixBot
    Comentar
  3. Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 2 %32 Logitech MBJ58 Mouse Support Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 3 %32
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    Pergunte ao FixBot
    Comentar
  4. Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Support Spring: passo 4, imagem 2 %32
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    Pergunte ao FixBot
    Comentar
  5. Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, imagem 1 %32 Logitech MBJ58 Mouse Support Spring Replacement, Attaching the New Spring: passo 5, imagem 2 %32
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 5-14, Forte Winter 2013 Membro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membros
Autoria de 23 guias
1Comentário do guia
The thing with the spring - still in 2024 helpful!
Thanks a lot! :-)
Michaela Meyer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 80
Ao todo: 5,186
