Ir para o conteúdo principal
Logitech MBJ58 Mouse Resistance Spring Replacement
O que você precisa
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: passo 1, imagem 1 %32
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - Responder
    There may be a sticker covering the screw hole.
    Eric Jensen - Responder
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: passo 2, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement: passo 2, imagem 2 %32
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - Responder
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 2 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, imagem 3 %32
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - Responder
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - Responder
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: passo 4, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: passo 4, imagem 2 %32
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - Responder
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: passo 5, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: passo 5, imagem 2 %32
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    h sh - Responder
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 2 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, imagem 3 %32
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    نحوه قرارگیری فلز سمت چپ چرخ اسکرول
    h sh - Responder
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: passo 7, imagem 1 %32 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: passo 7, imagem 2 %32
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: passo 8, imagem 1 %32
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
    Thank you, thank you, THANK YOU! Worked for Click! Cordless Optical too. I had taken the mouse cover off for cleaning. It was a mess inside. Lifting the wheel out, those two springs fell off. I had no clear idea how to re-assemble them... until you. How much do I owe you? I'd gladly pay.
    Lawrence
    Lawrence W. McAllister - Responder
Conclusão
14 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 5-14, Forte Winter 2013 Membro de Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
Membros da 5
Autoria de 21 guias
10 comentários
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - Responder
The spring installation details were lifesavers. Thank you!
LB
byard - Responder
thank you! could not have done it without your help.
taiyo_yuden_dvd - Responder
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - Responder
Thank you so much!! You made it very easy and quick!
vulcanmeister - Responder
Used this to figure out how to return the support spring to the correct position for a model M-BJ67B.
THANKS!!
fracjackmac - Responder
Do you have a part number for the resistance spring? I dropped mine and can’t find a new one on the Internet anywhere.
Aidan Franits - Responder
The spring fell out when I took mine apart (without reading these instructions) your guide was amazingly useful and clear for me to successfully put it back together. Thank you
Jom Bom - Responder
Also works for Lenovo M-UAE119
Andy Higgs - Responder
Where can you buy a replacement spring for the click part? My boyfriend dropped it on the ground while trying to examine it and it's so tiny it disappeared, he really likes this mouse so he doesn't want to just buy a new one. Does anyone sell the individual tiny springs under the click part of the mouse?
lil_e - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 84
Duração total: 10,979
