Ir para o conteúdo principal
Logitech M215 Scroll Wheel Replacement
O que você precisa
  1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: passo 1, imagem 1 %32 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: passo 1, imagem 2 %32 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: passo 1, imagem 3 %32
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
    The battery lid lifts up from the back. It does not slide back.
    Bob Peters - Responder
    U need to keep clean…& battery compartment needs gently pried off. Make sure to put back lid cover, pushing down on black prong..OR will not make contact.
    cconradmoore - Responder
    Thanks to u, i succeeded
    aresa0519 - Responder
  2. Logitech M215 Scroll Wheel Replacement, Remove old battery: passo 2, imagem 1 %32
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
    After replacing battery light goes on then off. I tried it twice. Do I need a new part.
    Elsie Sarkisian - Responder
    After replacing battery the remote green light goes on then off. I tried it twice
    What do u mean reverse order?
    The laser light did not go on
    Thank you this worked nicely
    - Reworld - - Responder
  3. Logitech M215 Scroll Wheel Replacement, Button Plate: passo 3, imagem 1 %32 Logitech M215 Scroll Wheel Replacement, Button Plate: passo 3, imagem 2 %32
    • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
  4. Logitech M215 Scroll Wheel Replacement, Pry off buttons: passo 4, imagem 1 %32 Logitech M215 Scroll Wheel Replacement, Pry off buttons: passo 4, imagem 2 %32
    • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
    • The button plate should be able to be completely removed at this point.
  5. Logitech M215 Scroll Wheel Replacement, Scroll Wheel: passo 5, imagem 1 %32
    • Use the prying tool to remove the scroll wheel. The wheel is held in place by two pegs which stick into the plastic holder.
Conclusão
9 outras pessoas executaram este guia.
Hannah Pate
Membro desde: 01/30/15
1.734 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 1-1, Watkins Winter 2015 Membro de USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
Membros da 4
Autoria de 28 guias
6 comentários
glad I was able to find this info on disassembly. Gave it a good cleaning and works better than it did before. Had the Phillips screwdriver. and used another small screwdriver and a small pocket knife to pry with. Be gentle - doesn’t look like it would take much force to break those plastic bits.
carmenanddave - Responder
Thanks! Mouse wheel windows were blocked by lint.
levensonjb - Responder
Very useful. Cleaned coffee out of mouse wheel spokes/windows and off of chipboard. Works better than before. Thanks!
OGrady Watson - Responder
Probably the BROWN stuff wasn’t coffee, I too cleaned the spokes/windows. the brown stuff is oil from out hands which lands on scroll wheel, then by heat gets transferred to the spokes. touch a finger on the mirror, the fingerprint on the mirror is because of OIL on hands. it is the same oil in that mouse wheel spokes.
tejaswin_jain -
There is a spring here connected to the wheel. Seems to be the thing to give tactical feedback when scrolling. It fell out when I took out the wheel not 100% how to put it back
Dan Molnar - Responder
If the 2 main (left/right) microswitches are failing - 1) re-melt the solder joints adding a tiny bit of fresh lead solder - this will get rid of dry solder joints and 2) clean the microswitches (logitech brand). You disasemble them by gently prying the latches on the long sides - small carpet knife is useful. There is a tiny white/semi-translucent bit of plastic - the push button , don’t lose it. Once the mechanism, spring and tiny ball contact are exposed, you can clean the contacts (rear of the microswitch) - I recommend spraying a bit with contact spray first (not the WD40 lubricant type!), then cut a 3-4mm wide and 3-4cm long stripe of sand paper (1000 grit) and clean both sides of ball contact, then spray the contact spray again. You can also take the spring/blade off and clean the recess where the blade is mounted against and touches the top switch pin. Careful with assembly of the blade - the top and middle pins have recesses where the blade and the blade spring should sit. Fiddly but easily doable.
groszek76 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 71
Duração total: 12,549
