Ir para o conteúdo principal
Logitech K750 Keyboard Battery Replacement
O que você precisa
  1. Logitech K750 Keyboard Battery Replacement, Turn off the keyboard: passo 1, imagem 1 %32
    • Before you begin, flip the keyboard's power switch into the OFF position.
  2. Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: passo 2, imagem 1 %32 Logitech K750 Keyboard Battery Replacement, Flip the keyboard over: passo 2, imagem 2 %32
    • Flip the entire keyboard over, keys facing down.
  3. Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: passo 3, imagem 1 %32 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: passo 3, imagem 2 %32 Logitech K750 Keyboard Battery Replacement, Pry open the battery tray: passo 3, imagem 3 %32
    • The ML2032 rechargeable coin cell battery is located in a tray at the back edge of the keyboard.
    • Insert the flat end of a spudger into the gap between the battery tray and the top surface of the keyboard.
    • Pivot the spudger down, towards the top of the keyboard, to begin to pry the tray out of its cavity.
  4. Logitech K750 Keyboard Battery Replacement, Remove the battery tray: passo 4, imagem 1 %32 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: passo 4, imagem 2 %32 Logitech K750 Keyboard Battery Replacement, Remove the battery tray: passo 4, imagem 3 %32
    • Use the flat end of the spudger to push the battery tray out and away from the keyboard.
    • The tray is held in by small "ears" and may take a significant amount of force to dislodge.
    • If you're having trouble, use the end of a spudger or a flat blade screwdriver to "walk" the tray out, pushing on alternating sides instead of directly in the middle.
    • Remove the battery tray.
    • During reassembly, firmly push the battery tray into its slot until it clicks into place.
  5. Logitech K750 Keyboard Battery Replacement, Remove the battery: passo 5, imagem 1 %32 Logitech K750 Keyboard Battery Replacement, Remove the battery: passo 5, imagem 2 %32 Logitech K750 Keyboard Battery Replacement, Remove the battery: passo 5, imagem 3 %32
    • Push the battery out of the tray to remove it.
    • Note the battery orientation—it can only go in one way. Set the battery into the tray with side with the text and the "+" sign facing down.
    • Use only a rechargeable ML2032 coin cell battery as a replacement. Although it's the same size and shape as the more common CR2032, CR2032s are not rechargeable.
Conclusão
210 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
155.250 Reputação
Autoria de 439 guias
95Comentários do guia
Thank you. Worked perfectly. Gained trust in this site. Lost respect for Logitech.
henry - Responder
My sentiments, exactly!
Melinda Mcvay -
There a better way to open it
put the knife or better a screwdriver on the other side (keys upside); worked for me without damage the keyboard :D
yannick NR - Responder
Thank You! That did work much better!
Matt Anderson -
Here is an even better method.
You can also totally prevent damage by finding a laminated biz card and cutting it into 2 one inch strips and inserting both of them into the slot on the top side (solar side) of the battery compartment.
Then get your tool ( I like small pointed scissors) and pry it out between the cards.
Very easy!
David Powers -
Comentar
Visualizações:
Últimas 24 horas: 49
Últimos 7 dias: 790
Últimos 30 dias: 2,175
Ao todo: 280,605
