Ir para o conteúdo principal
Logitech K480 Flex Circuit Replacement
O que você precisa
  1. Logitech K480 Flex Circuit Replacement, Back Cover: passo 1, imagem 1 %32
    • Flip the keyboard over.
  2. Logitech K480 Flex Circuit Replacement: passo 2, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 2, imagem 2 %32 Logitech K480 Flex Circuit Replacement: passo 2, imagem 3 %32
    • Remove the four rubber feet with a spudger.
  3. Logitech K480 Flex Circuit Replacement: passo 3, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 3, imagem 2 %32 Logitech K480 Flex Circuit Replacement: passo 3, imagem 3 %32
    • Slide open battery panel.
    • Remove the batteries.
  4. Logitech K480 Flex Circuit Replacement: passo 4, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 4, imagem 2 %32
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
  5. Logitech K480 Flex Circuit Replacement: passo 5, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 5, imagem 2 %32
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
  6. Logitech K480 Flex Circuit Replacement: passo 6, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 6, imagem 2 %32 Logitech K480 Flex Circuit Replacement: passo 6, imagem 3 %32
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
  7. Logitech K480 Flex Circuit Replacement, Metal Plate: passo 7, imagem 1 %32 Logitech K480 Flex Circuit Replacement, Metal Plate: passo 7, imagem 2 %32 Logitech K480 Flex Circuit Replacement, Metal Plate: passo 7, imagem 3 %32
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
  8. Logitech K480 Flex Circuit Replacement: passo 8, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 8, imagem 2 %32
    • Lift up and remove the metal plate.
  9. Logitech K480 Flex Circuit Replacement, Flex Circuit: passo 9, imagem 1 %32 Logitech K480 Flex Circuit Replacement, Flex Circuit: passo 9, imagem 2 %32
    • Remove the two black 4 mm screws from the motherboard with a Phillips #00 screwdriver.
  10. Logitech K480 Flex Circuit Replacement: passo 10, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 10, imagem 2 %32
    • Gently pull the flex circuit from the back of the motherboard.
    • The flex circuit is fragile so be gentle when pulling it out.
  11. Logitech K480 Flex Circuit Replacement: passo 11, imagem 1 %32 Logitech K480 Flex Circuit Replacement: passo 11, imagem 2 %32
    • Remove the two black 4 mm screws from the dial motherboard below the regular motherboard with a Phillips #00 screwdriver.
  12. Logitech K480 Flex Circuit Replacement: passo 12, imagem 1 %32
    • Gently pull the circuit sheet from behind the dial motherboard.
  13. Logitech K480 Flex Circuit Replacement: passo 13, imagem 1 %32
    • Remove the two black 4 mm screws holding the Bluetooth component on the left side using a Phillips #00 screwdriver.
  14. Logitech K480 Flex Circuit Replacement: passo 14, imagem 1 %32
    • Lift the flex circuit and remove.
Conclusão
Madison
Membro desde: 09/04/24
688 Reputação
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 313
