Ir para o conteúdo principal
Logitech K120 Keycap Removal
O que você precisa
  1. Logitech K120 Keycap Removal, Removing The Small Keycaps: passo 1, imagem 1 %32 Logitech K120 Keycap Removal, Removing The Small Keycaps: passo 1, imagem 2 %32
    • For small keycaps (1st image), the only tool needed is a spudger. Pry the keycap off by wedging a spudger beneath the key and prying up. (Shown in 2nd image)
    • Preferably, use a plastic spudger. A metal spudger may damage the keycap.
    Pergunte ao FixBot
    Comentar
  2. Logitech K120 Keycap Removal, Removing Large Keycaps: passo 2, imagem 1 %32 Logitech K120 Keycap Removal, Removing Large Keycaps: passo 2, imagem 2 %32
    • When removing large keycaps (shown in image 1), a metal bracket connects the keycap to the front chassis. (Image 2) Use a spudger to separate the bracket from the keycap.
    Pergunte ao FixBot
    Comentar
Conclusão
The key caps on the Logitech K120 keyboard are very easy to remove, you just need to pry a bit.
7 outras pessoas executaram este guia.
Camuise
Membro desde: 11/22/18
1.673 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 154
Ao todo: 16,250
