Ir para o conteúdo principal
Logitech K120 Keyboard Disassembly
O que você precisa
Vídeo de Apresentação
  1. Logitech K120 Keyboard Disassembly, Removing Screws: passo 1, imagem 1 %32 Logitech K120 Keyboard Disassembly, Removing Screws: passo 1, imagem 2 %32
    • Remove the Phillips #000 screw. Turn the screwdriver counter-clockwise.
  2. Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: passo 2, imagem 1 %32 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: passo 2, imagem 2 %32 Logitech K120 Keyboard Disassembly, Separating The Keyboard's Chassis: passo 2, imagem 3 %32
    • Use the spudger to separate the top of keyboard from the bottom of the keyboard.
  3. Logitech K120 Keyboard Disassembly, Removing The Top Of The Keyboard: passo 3, imagem 1 %32
    • Remove the top of the keyboard and put it aside.
  4. Logitech K120 Keyboard Disassembly, Removing The Bracket: passo 4, imagem 1 %32 Logitech K120 Keyboard Disassembly, Removing The Bracket: passo 4, imagem 2 %32 Logitech K120 Keyboard Disassembly, Removing The Bracket: passo 4, imagem 3 %32
    • Unscrew the highlighted screws using a Phillips #000 Screwdriver. Turn the screwdriver counter-clockwise.
  5. Logitech K120 Keyboard Disassembly, Removing The Circuit Board: passo 5, imagem 1 %32 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: passo 5, imagem 2 %32 Logitech K120 Keyboard Disassembly, Removing The Circuit Board: passo 5, imagem 3 %32
    • Use the spudger and carefully pry the connector out of its socket. (Highlighted in the pictures)
  6. Logitech K120 Keyboard Disassembly, Removing The Cable: passo 6, imagem 1 %32 Logitech K120 Keyboard Disassembly, Removing The Cable: passo 6, imagem 2 %32
    • Carefully nudge the connector out of the hole in which the cable enters the keyboard's chassis.
  7. Logitech K120 Keyboard Disassembly, Removing The Membrane: passo 7, imagem 1 %32 Logitech K120 Keyboard Disassembly, Removing The Membrane: passo 7, imagem 2 %32
    • Peel the membrane off carefully so that the membrane doesn't rip.
  8. Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: passo 8, imagem 1 %32 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: passo 8, imagem 2 %32 Logitech K120 Keyboard Disassembly, Remove The 2nd Membrane: passo 8, imagem 3 %32
    • Stick the sharp end of the spudger into the corner of the second membrane and bring the spudger partly underneath the membrane.
    • Lift the membrane off of the first standoff.
    • Peel the rest of the membrane off carefully so the membrane doesn't rip.
Linha de Chegada
Marcus Jones
Membro desde: 11/22/18
1.205 Reputação
Autoria de 6 guias
2 comentários
I followed your guide for disassembly and did the opposite for reassembly, now all three leds turn on when plugged in but none of the keys respond. Any idea what I should do?
Jacob Sileski - Responder
Make sure that the rubber membrane is making contact with the pads on the plastic sheets. If they are, make sure the connector is fully plugged in. If it is, make sure the keyboard is plugged into the right USB port.
Marcus Jones -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 39
Últimos 30 dias: 155
Duração total: 10,091
