Introdução
The Harmony Hub acts as a middle-man between devices and the remote. It has very few parts, making it a simple fix. The most difficult part of this guide is revealing the hub after removing the screws on the exterior. Once the hub is open, removing the motherboard requires just a few more screws to be removed and the release of a small tab that keeps the motherboard in place.
O que você precisa
Peel off the rubber pads.
Remove the four 6mm Phillips #0 screws from the bottom of the hub.
Remove the single 6 mm Phillips #0 screw from the motherboard.
Pull the black tabs back and lift the motherboard.
