Ir para o conteúdo principal
Logitech Harmony Ultimate Charging Station Motherboard Replacement
O que você precisa
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, imagem 1 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, imagem 2 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: passo 1, imagem 3 %32
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 2, imagem 1 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, imagem 1 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, imagem 2 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 3, imagem 3 %32
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, imagem 1 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, imagem 2 %32 Logitech Harmony Ultimate Charging Station Motherboard Replacement: passo 4, imagem 3 %32
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Conclusão
Lucas Reynolds
Membro desde: 09/01/15
339 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-1, Eyestone Fall 2015 Membro de USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
Membros da 5
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 2,919
