Ir para o conteúdo principal
Logitech Harmony Ultimate Buttons Replacement
O que você precisa
  1. Logitech Harmony Ultimate Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Remove the single 6 mm Phillips #0 screw located beneath the sticker near the USB charging port.
  2. Logitech Harmony Ultimate Buttons Replacement: passo 2, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement: passo 2, imagem 2 %32
    • Use a plastic opening tool to release tabs that hold the front panel and back panel together. There are three tabs on each side of the device that need to separate for the device to open.
    • The use of a plastic opening tool is recommended to avoid damaging the remote. Use stronger tools as a last resort.
    • Be careful on the right side (looking at the back side) not to hit the screen ribbon cable. If that is hit and breaks, the touchscreen will not work properly. (example shown in the image)
  3. Logitech Harmony Ultimate Buttons Replacement: passo 3, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement: passo 3, imagem 2 %32
    • Disconnect the wires running from the back cover to the motherboard.
  4. Logitech Harmony Ultimate Buttons Replacement: passo 4, imagem 1 %32
    • Remove the four 6mm Phillips #0 screws from the battery case.
  5. Logitech Harmony Ultimate Buttons Replacement: passo 5, imagem 1 %32
    • The battery is still connected to the device via wiring. To free the battery completely, remove the dark plastic piece from the slot with the plastic opening tool. Slowly rotate the dark plastic piece and the battery clockwise until then can be removed from underneath the small circuit board with the USB port.
    • Removing the dark plastic piece from the motherboard takes some patience, as the remote is designed so that the battery will not dislocate under extreme conditions. The small circuit board with the USB port remains connected to the motherboard by six 10 mm pins.
  6. Logitech Harmony Ultimate Buttons Replacement: passo 6, imagem 1 %32
    • Lift the battery and its case out of the remote.
    • The battery should still be connected to the case with adhesive.
  7. Logitech Harmony Ultimate Buttons Replacement: passo 7, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement: passo 7, imagem 2 %32
    • Use the plastic opening tool to separate the battery from the case.
  8. Logitech Harmony Ultimate Buttons Replacement, Motherboard: passo 8, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement, Motherboard: passo 8, imagem 2 %32
    • Remove the four 6mm Phillips #0 screws from the motherboard.
  9. Logitech Harmony Ultimate Buttons Replacement: passo 9, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement: passo 9, imagem 2 %32
    • There is a flap that connects to the motherboard from the plastic casing. Use fingernails to safely release the flap by flipping the small black buckle upwards.
    • The flap and buckle are underneath the clear yellow piece of tape.
    • Be very careful as damaging this flap could permanently damage your controller.
  10. Logitech Harmony Ultimate Buttons Replacement: passo 10, imagem 1 %32
    • The motherboard is now safe to remove by sliding and lifting it backwards out of place.
  11. Logitech Harmony Ultimate Buttons Replacement, Buttons: passo 11, imagem 1 %32 Logitech Harmony Ultimate Buttons Replacement, Buttons: passo 11, imagem 2 %32
    • After successfully removing the motherboard, you can easily peel off the buttons from the controller frame.
Conclusão
5 outras pessoas executaram este guia.
Aaron Diaz
Membro desde: 08/31/15
716 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 8-1, Eyestone Fall 2015 Membro de USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 Membros
Autoria de 9 guias
2Comentários do guia
This is a great demo and it give me much more confidence to tackle the repair. I have some questions. Does the battery need to be removed as I see from your pictures, the motherboard screws are not covered by the battery - or are they? Also, where do you purchase your repair parts? Thank you!
Steve Feldner - Responder
Where do you find the parts? The Logitech website doesn’t have parts for the Ultimate
larrybud2004 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 75
Ao todo: 6,379
