Ir para o conteúdo principal
Logitech Harmony Touch Motherboard Replacement
O que você precisa
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Logitech Harmony Touch Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: passo 2, imagem 1 %32 Logitech Harmony Touch Motherboard Replacement: passo 2, imagem 2 %32 Logitech Harmony Touch Motherboard Replacement: passo 2, imagem 3 %32
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Conclusão
Equipe
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 695
