Introdução
The motherboard is a central part in the operation of your Companion remote. If your remote is not working after adjusting the settings and replacing the battery, you may need to replace the motherboard. All you need for this guide is a plastic opening tool and a Phillps #0 screwdriver.
O que você precisa
4 outras pessoas executaram este guia.
Um comentário
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
