Ir para o conteúdo principal
Logitech Harmony Companion Remote Motherboard Replacement
O que você precisa
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: passo 1, imagem 1 %32
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: passo 2, imagem 1 %32
    • Push the battery cover upward.
  3. Logitech Harmony Companion Remote Motherboard Replacement: passo 3, imagem 1 %32 Logitech Harmony Companion Remote Motherboard Replacement: passo 3, imagem 2 %32 Logitech Harmony Companion Remote Motherboard Replacement: passo 3, imagem 3 %32
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: passo 4, imagem 1 %32 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: passo 4, imagem 2 %32
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: passo 5, imagem 1 %32 Logitech Harmony Companion Remote Motherboard Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: passo 6, imagem 1 %32 Logitech Harmony Companion Remote Motherboard Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to remove the motherboard.
Conclusão
4 outras pessoas executaram este guia.
Cassidy Wardlow
Membro desde: 09/28/17
662 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G3, Nance Fall 2017 Membro de USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
Membros da 3
Autoria de 4 guias
Um comentário
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 87
Duração total: 5,696
