Introdução
If you are having trouble with your Harmony Hub, the motherboard may need to be replaced. For this guide, all you need is a Phillips #0 screwdriver. There are many screws, so be sure to set them on a mat so none of them get lost.
O que você precisa
Remove the non-slip rubber pads on the bottom of the Harmony Hub.
Conclusão
