Ir para o conteúdo principal
Logitech Harmony Companion Harmony Hub Motherboard Replacement
O que você precisa
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, imagem 1 %32 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: passo 1, imagem 2 %32
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, imagem 1 %32 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 2, imagem 2 %32
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 3, imagem 1 %32
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, imagem 1 %32 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 4, imagem 2 %32
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, imagem 1 %32 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, imagem 2 %32 Logitech Harmony Companion Harmony Hub Motherboard Replacement: passo 5, imagem 3 %32
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Conclusão
Cassidy Wardlow
Membro desde: 09/28/17
689 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G3, Nance Fall 2017 Membro de USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 513
