Ir para o conteúdo principal
Logitech Harmony Companion Button Pad Replacement
O que você precisa
  1. Logitech Harmony Companion Button Pad Replacement, Remote Battery: passo 1, imagem 1 %32
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Button Pad Replacement: passo 2, imagem 1 %32
    • Push the battery cover upward.
  3. Logitech Harmony Companion Button Pad Replacement: passo 3, imagem 1 %32 Logitech Harmony Companion Button Pad Replacement: passo 3, imagem 2 %32 Logitech Harmony Companion Button Pad Replacement: passo 3, imagem 3 %32
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, imagem 1 %32 Logitech Harmony Companion Button Pad Replacement, Remote Motherboard: passo 4, imagem 2 %32
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Button Pad Replacement: passo 5, imagem 1 %32 Logitech Harmony Companion Button Pad Replacement: passo 5, imagem 2 %32
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Button Pad Replacement: passo 6, imagem 1 %32 Logitech Harmony Companion Button Pad Replacement: passo 6, imagem 2 %32
    • Use the plastic opening tool to remove the motherboard.
  7. Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, imagem 1 %32 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, imagem 2 %32 Logitech Harmony Companion Button Pad Replacement, Button Pad: passo 7, imagem 3 %32
    • Lift the button pad up to remove it from the remote.
Conclusão
3 outras pessoas executaram este guia.
Cassidy Wardlow
Membro desde: 09/28/17
716 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G3, Nance Fall 2017 Membro de USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membros
Autoria de 4 guias
4Comentários do guia
Ou pouvons nous commander «  Logitech Harmony Companion Button Pad Replacement »
Roger Tardif - Responder
Where can I purchase the button pad?
elijah - Responder
Also looking to find where to purchase. I called Logitech and they were clueless. My 4 year old was better equipped to respond.
Joshua Fuller - Responder
Thanks for posting these helpful steps. My harmony Companion was frustrating us because we had to press buttons really hard.
Cy Beaux - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 3,529
