Introdução
This guide will involve using basic tools to replace the case of the Logitech Harmony 950.
O que você precisa
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #1 screwdriver to remove the (3) three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
3 outras pessoas executaram este guia.
3 comentários
where can this casing be purchased?
Parts are required obviously!!
Is the usb bottom cap part of the replacement case? If not can u get one?
