Ir para o conteúdo principal
Logitech Harmony 900 Button Pad Replacement
O que você precisa
  1. Logitech Harmony 900 Button Pad Replacement, Battery: passo 1, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement, Battery: passo 1, imagem 2 %32
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Button Pad Replacement: passo 2, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 2, imagem 2 %32
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Button Pad Replacement, Motherboard: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Button Pad Replacement: passo 4, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 4, imagem 2 %32
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Button Pad Replacement: passo 5, imagem 1 %32
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Button Pad Replacement: passo 6, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 6, imagem 2 %32
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Button Pad Replacement: passo 7, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 7, imagem 2 %32
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Button Pad Replacement: passo 8, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 8, imagem 2 %32
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Button Pad Replacement: passo 9, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement: passo 9, imagem 2 %32
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Button Pad Replacement: passo 10, imagem 1 %32
    • Using your hands, carefully separate the motherboard from the rest of the remote.
  11. Logitech Harmony 900 Button Pad Replacement, Button Pad: passo 11, imagem 1 %32 Logitech Harmony 900 Button Pad Replacement, Button Pad: passo 11, imagem 2 %32
    • Peel off the button pads from the device frame.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Hanks
Membro desde: 09/25/17
442 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team S4-G5, Eyestone Fall 2017 Membro de USF Tampa, Team S4-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S4G5
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 956
