Ir para o conteúdo principal
Logitech Harmony 300 Batteries Replacement
O que você precisa
  1. Logitech Harmony 300 Batteries  Replacement, Identifying the Battery Housing: passo 1, imagem 1 %32
    • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  2. Logitech Harmony 300 Batteries  Replacement, Removing the Battery Cap: passo 2, imagem 1 %32
    • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
    • Once the cap is loosen, simply lift the cap out to reveal the batteries.
  3. Logitech Harmony 300 Batteries  Replacement, The Batteries: passo 3, imagem 1 %32 Logitech Harmony 300 Batteries  Replacement, The Batteries: passo 3, imagem 2 %32
    • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
Conclusão
Uma outra pessoa concluiu este guia.
Andres Rodriguez
Membro desde: 10/09/14
137 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-29, Donnelly Fall 2014 Membro de USF Tampa, Team 1-29, Donnelly Fall 2014
USFT-DONNELLY-F14S1G29
1 Membro
1 Guia de autoria
5 comentários
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - Responder
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - Responder
it’s impossible !!!
Pascal jade - Responder
I agree with the other comments. I’ll keep trying, but so far after 10 minutes I still can’t get the cover to budge.
Barry Boehm - Responder
pefI too found the battery cover impossible to remove “by hand”. I used the clear plastic package as a cradle for the device,
then used a flat-blade screwdriver applied to the indent where you are meant to push by hand, and pushed hard at about
about a 45° angle. Finally got it open! I filed off a bit of the hook on the cover latch so hopfully it will be easier next time.
Dave Davy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 2,260
