Ir para o conteúdo principal
Logitech G910 Lights Replacement
O que você precisa
  1. Logitech G910 Lights Replacement, Lights: passo 1, imagem 1 %32
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: passo 2, imagem 1 %32
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: passo 3, imagem 1 %32
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: passo 4, imagem 1 %32 Logitech G910 Lights Replacement, Lift the film: passo 4, imagem 2 %32
    • Gently lift up the plastic film in the top right corner.
Conclusão
5 outras pessoas executaram este guia.
3 comentários
So what do I do after I take apart my keyboard?
CuddlyZebesian - Responder
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 98
Duração total: 6,094
