Pular para o conteúdo principal
Introdução
This guide will help you remove a key from the keyboard. You'll want to use a plastic or metal spudger to remove the keys from the keyboard.
Peças
Nenhum componente especificado.
  1. Unplug the keyboard cord from the computer.
    • Unplug the keyboard cord from the computer.
  2. Turn the keyboard over and remove all the screws from the back. Turn the keyboard over and remove all the screws from the back.
    • Turn the keyboard over and remove all the screws from the back.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Turn the keyboard back and remove the screws from the front.
    • Turn the keyboard back and remove the screws from the front.
  5. Using a metal spudger, gently slide it under the cover. Use your hand to add more pressure.
    • Using a metal spudger, gently slide it under the cover. Use your hand to add more pressure.
    • (Note: be careful to not give too much pressure that could break the keyboard)
  6. Gently remove the key button from the device.
    • Gently remove the key button from the device.
Conclusão
2 outras pessoas concluíram este guia.
I am sorry, but why did you wrote a tutorial and describe how to open up G910 (and lose the warranty along the way) just to take of the keyCAP?
Keycap can be removed in a matter of seconds with use of $0.99 keycap removal tool
https://www.ebay.com/itm/Keyboard-Key-Ke...
heggathestrasni - Responder
It’s not just the Key Cap, you can remove the mechanical switch too. I have a busted G910 and I’ve been wanting to replace the switches for a while now.
Wildcard001 -
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 32
Últimos 7 dias: 201
Últimos 30 dias: 852
Todo: 7,755
