Ir para o conteúdo principal
Logitech G733 Power Button Replacement
O que você precisa
  1. Logitech G733 Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently start to pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
    • Remove the ear pad.
  2. Logitech G733 Power Button Replacement: passo 2, imagem 1 %32 Logitech G733 Power Button Replacement: passo 2, imagem 2 %32
    • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
  3. Logitech G733 Power Button Replacement: passo 3, imagem 1 %32 Logitech G733 Power Button Replacement: passo 3, imagem 2 %32 Logitech G733 Power Button Replacement: passo 3, imagem 3 %32
    • Gently lift off the speaker housing, with care not to strain the connected cable.
    • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
    • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
    • The scroll wheel may fly out when you pop the circuit board out.
  4. Logitech G733 Power Button Replacement: passo 4, imagem 1 %32 Logitech G733 Power Button Replacement: passo 4, imagem 2 %32
    • Once the motherboard is loose, gently pull the wire out of its harness.
    • The wiring harness is glued, so be careful with it. It should pull out easily.
  5. Logitech G733 Power Button Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    Halberd Spudger
    $2.99
    • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
    • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
    • This step is the most difficult, so be careful when prying.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 95
Ao todo: 2,453
