Introdução
Use this guide to replace the battery in a Logitech G703 wireless gaming mouse.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
This guide requires removing the mouse feet. If you’re planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
You might need replacement adhesive to reattach components when reassembling the device.
O que você precisa
Before you begin, flip the mouse's power switch into the red OFF position.
Heat an iOpener and apply it to the bottom mouse foot for two minutes.
Slide an opening pick under an edge of the bottom mouse foot.
Slide the pick under the rest of the foot until you can lift it off the mouse.
Remove the foot.
Repeat the procedure to remove the top mouse foot.
Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
Peel the adhesive off.
Use a Phillips screwdriver to remove the four 5.4 mm screws securing the two halves of the mouse together.
Grasp the mouse case at the back and pull the two halves apart slightly, so there's a gap at the back of the mouse.
Insert a spudger into the small gap between the top and the bottom mouse case right above the charging port.
Pry open the mouse clips by tilting the spudger upwards to separate the two mouse halves.
Use the flat end of a spudger to gently lift the black sliding lock on the interconnect cable socket until it stops and the cable is no longer locked in.
Slide the interconnect cable out of its socket on the motherboard.
Use a pair of blunt tweezers to grasp the sides of the battery connector.
Pull the connector up and out of its socket, gently rocking it back and forth to loosen the clips securing it.
Use a Phillips screwdriver to remove the two 3.4 mm screws securing the battery housing to the bottom half of the mouse.
Heat an iOpener and apply it to the back of the battery housing for two minutes.
Insert an opening pick between the long edge of the battery and its housing opposite the battery cable.
Slide the opening pick under the battery and lift up to pry the battery off of its housing.
Remove the battery.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
3 outras pessoas executaram este guia.
3 comentários
What's the reason for not being able to use the old battery again? I don't understand why plugging the stock back into the mouse would be a fire hazard?
Hi Ryan,
the warning applies more in relation to a removed battery than to one which was only disconnected. A removed one could be bent or have other damages that are not immediately visible and could cause damage to the mouse, fire or a thermal event or may leak dangerous chemicals. However, this is not necessarily the case, but there is always the possibility. That is why we warn and point this out within the repair guide.
