Ir para o conteúdo principal
Logitech G602 Side Motherboard Replacement
O que você precisa
  1. Logitech G602 Side Motherboard Replacement, Side Motherboard: passo 1, imagem 1 %32
    • Use a blue spudger to pry all 4 mice feet from the bottom of the mouse.
  2. Logitech G602 Side Motherboard Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from underneath the mice feet.
  3. Logitech G602 Side Motherboard Replacement: passo 3, imagem 1 %32 Logitech G602 Side Motherboard Replacement: passo 3, imagem 2 %32
    • Use the blue spudger to prop open the bottom battery port.
    • Remove the AA batteries.
  4. Logitech G602 Side Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  5. Logitech G602 Side Motherboard Replacement: passo 5, imagem 1 %32 Logitech G602 Side Motherboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to grip and pull the white ribbon cable from the motherboard.
  6. Logitech G602 Side Motherboard Replacement: passo 6, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove both screws (3x5mm ) from above the side motherboard.
  7. Logitech G602 Side Motherboard Replacement: passo 7, imagem 1 %32
    • Use a Phillips #00 screwdriver and unscrew both screws from the side motherboard.
    • We used a set of pliers and a Phillips #00 screw bit because the screwdriver couldn't fit into the side of the device.
  8. Logitech G602 Side Motherboard Replacement: passo 8, imagem 1 %32
    • Use a black spudger and your fingers to loosen and remove the side motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Is the white momentary switch the middle click button?
I have a couple of G602's that have failing middle click buttons, and if it's the momentary switch, it looks like an easy fix.
Agit - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 43
Duração total: 3,705
