Ir para o conteúdo principal
Logitech G602 Scroll Wheel Replacement
O que você precisa
  1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: passo 1, imagem 1 %32
    • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
  2. Logitech G602 Scroll Wheel Replacement: passo 2, imagem 1 %32
    • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
  3. Logitech G602 Scroll Wheel Replacement: passo 3, imagem 1 %32 Logitech G602 Scroll Wheel Replacement: passo 3, imagem 2 %32
    • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
  4. Logitech G602 Scroll Wheel Replacement: passo 4, imagem 1 %32
    • Use the black spudger to move the tip of the metal spring off of the wheel.
    • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
Conclusão
8 outras pessoas executaram este guia.
2 comentários
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - Responder
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 106
Duração total: 8,234
